Programming Notes:А скажите пожалуйста. У меня только один брелок управления центральным замком, как сделать второй, можно ли просто купить абсолютно любой такой же брелок и привязать его к своей машине? Если да, то как это сделать?
You must have one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
Step-by-Step Programming Instructions:
1) Turn ignition to run position (as far as you can go without starting engine).
2) Using any working remote, press the UNLOCK button for 4 to 10 seconds.
3) Within the specified 4 to 10 seconds, continue pressing the UNLOCK buton and press the PANIC button for 1 second and release both buttons at the same time. A chime will sound within 3 seconds to indicate that the vehicle has entered remote programming mode.
4) Within 30 seconds of the chime, press any button on all remotes to be programmed including previously programmed remotes. A chime will sound after each remote is programmed.
5) Turn ignition to OFF and remove key.
6) Programming is complete. Test all remotes.
